Fiesta RS1800 Electrical Problem Help
Old Jan 18, 2013 | 07:24 PM
nuno almeida's Avatar
nuno almeida
Default Fiesta RS1800 Electrical Problem Help
Good afternoon I have a Fiesta RS1800 June 1992 and have had electrical problems and the problem is that the car reaches normal temperature when the car goes down or the Fuel Pump stops working, already changed the pump, Relay has also been changed but the problem still do not know what goes thanked some help from you.
*** Is there a sensor that may conflict and cause the pump does not work?
*** Another problem is the water temperature sensor when I turn the ignition the pointer goes right into the middle of the indicator and changed the sensor and the problem remains to some of you guys would appreciate this has happened even help from you've been to a few mechanics and can not solve the problem or do not want to bother with the car ....
Old Jan 19, 2013 | 03:30 PM
martysmartie's Avatar
martysmartie
How do you know it's the fuel pump that stops working?
The ECU makes the fuel pump run, with the temperature gauge unplug the connection at the sender, then turn the ignition on, when you do this the gauge should not move...
Martin
Old Jan 20, 2013 | 09:59 AM
nuno almeida
I know that is the pump because as soon as the car turns off turn the ignition on again and I do not hear the fuel pump working and will give key and nothing done does not handle more
Old Jan 20, 2013 | 01:13 PM
martysmartie
Immobiliser problem then, perhaps.
The pump wll not aways prime, neccessarily.
Martin
Old Jan 20, 2013 | 03:02 PM
nuno almeida
My car dont have a immobiliser...
Old Jan 20, 2013 | 03:11 PM
nuno almeida
I'll see the mass of the car because the car switch so happens when it's hot or when it reaches normal operating temperature.
Old Jan 21, 2013 | 12:05 PM
martysmartie
Not even factory 'PATS'?
Martin
Old Jan 30, 2013 | 05:45 PM
nuno almeida
Personal pump is the problem solved despite being new pump was faulty took an electrician put the pump in a recipient with petrol and the pump worked well when it was cold and with a consumption of 200 mA for about 5 10 minutes to warm up, then the baixanto consumption would fall to 0 and stopped working. The only problem that remains is the temperature sensor ...
RSBryden
Sep 6, 2015 08:39 PM
hopper350
Sep 4, 2015 12:53 AM
Ben26
Sep 3, 2015 07:55 PM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
