2002 focus idle problem - warm startup
Old Jan 14, 2013 | 10:04 PM
richrsmith's Avatar
richrsmith
Default 2002 focus idle problem - warm startup
Hi,
I'm a newbie here.
I have a problem with idle speed on my 2002 1.6 petrol manual focus (145k on clock) after a warm start up.
When I come to a stop (either clutch down in gear or clutch up out of gear) the engine will rev to 2000rpm for 4-5 seconds, then return to normal idle speed 900rpm-ish. If I dip the clutch while moving, the engine will rev to 2000rpm but will not return to normal idle speed until 4-5 sec after coming to a stop. Once at the normal idle speed, any press of the throttle will then repeat the problem.
This problem is only present after a warm start up.
It is never present following a cold start no matter how long I drive for after the cold start (have driven for hours with no problem).
Once the engine is warm, if I turn off then re-start immediately the problem is present. This is repeatable every time.
This has only recently started to happen and is doing my nut in.
Any help is more than welcome!
Thanks
Old May 21, 2013 | 11:42 AM
richrsmith's Avatar
richrsmith
Found the problem eventually, it was a split PCV valve hose.
Still confused as to why it only palyed up from a warm start .
Never mind though, fixed now
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
muffster
13
Sep 3, 2015 09:40 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
Zoggon
Aug 10, 2015 10:39 AM
