[b]cosworth misfire [/b]
Old 10-03-2005, 10:19 PM
cpcossie
cpcossie's Avatar
Default [b]cosworth misfire [/b]
my 2wd cossie has developed a misfire throughout the rev range and is running bloody rich seems like the engine is flooding cos as you try to drive it cuts out, all the timings ok and i have changed the phase senor in the dizzy someone help i am running out of ideas
Old 10-03-2005, 10:40 PM
frog
0-60 in 17 seconds (eek)
frog's Avatar
Is that when it's cold, warm or both ?
If only when warm, check the blue temp sensor at the back of the head, it could be telling the car's cold when it's actually warm, hence running richer.
Whereabouts are you in Berkshire m8 ? I might be able to pop round at the week end to help you out - I've had a fair few misfires with mine...
Old 11-03-2005, 09:31 AM
cpcossie
cpcossie's Avatar
misfires all the time have got one of those sensors will be trying it today. The car is at work in Basingstoke but i live in slough, cheers m8
Old 11-03-2005, 12:16 PM
frog
frog's Avatar
Let us know how you get on.
Old 11-03-2005, 03:50 PM
cpcossie
cpcossie's Avatar
no good i have swapped the coolant sensor, air charge sensor and even put a 3 bar map sensor on it. problems still there also i cant seem to adjust the co on the ecu one of me mates has got a spare one i am going to try that see if it makes a difference will let you know m8.
Old 12-03-2005, 10:59 AM
frog
frog's Avatar
I take it you had a 3bar map sensor on there before, cos changing from a 2bar to a 3bar won't help matters
Old 13-03-2005, 08:09 PM
cpcossie
cpcossie's Avatar
i dont think it was a three bar map sensor, whats the difference?
Old 13-03-2005, 11:32 PM
frog
frog's Avatar
not 100% sure, 3 bar is usually only fitted to stage 3 cars.
If you have a 3 bar map sensor and a chip expects a 2 bar one, the chip will not interpret the map sensor readings properly and won't fuel the car as it should (amongst other things). It will either think the car is under more (or less - that's where I am not sure) than it actually is.
If you are not 100% sure what you are doing, give Mark Shead @ MADevelopments a call and see if you can book her in for him to have a look. He's in maindenhead so not far from slough.
He will most certainly sort your problem out, and it probably will cost you less in the long run.
His mobile number is: 07768 356204
Old 14-03-2005, 12:53 PM
cpcossie
cpcossie's Avatar
cheers buddy I'am going to try an ecu on it today other than that will give him a bell, also I have put the original 2 bar sensor on.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
05-11-2015 08:12 PM
natehall
Ford Focus (All Models)
08-09-2015 05:13 AM
Adam Graham
06-09-2015 06:04 AM
wheelwizardrefurbs
05-09-2015 10:52 AM
Quick Reply: [b]cosworth misfire [/b]
