4x4 conversion
Old Mar 10, 2005 | 01:05 PM
tenpotturbo's Avatar
tenpotturbo
Default 4x4 conversion
putting my 2wd saph to 4 wd do i only need to swap rear cradle (were diff bolts to) or swap everything arms as well also is a sierra 4x4 same as a cossie 4x4
Old Mar 10, 2005 | 03:41 PM
fernando_khan's Avatar
fernando_khan
i would have thought alot will be needed to change...why not sell it and just buy a 4wd???? thats if you havent got major mods already....
Old Mar 10, 2005 | 06:35 PM
tenpotturbo
done every thing else just need to know about rear beam as i need to fit 4x4 diff
Old Mar 10, 2005 | 06:49 PM
rosco's Avatar
rosco
you've got to fit the whole beam or you just move the two top lugs where the diff bolts onto the beam cause the 4wd diff is half an inch smaller than the 2wd
Old Mar 10, 2005 | 06:56 PM
tenpotturbo
so i don,t need to swap all trailing arms then just beam
Old Mar 10, 2005 | 07:02 PM
tenpotturbo
is a xr 4x4 beam same as cosse one
Old Mar 11, 2005 | 08:14 PM
s3rst's Avatar
s3rst
yes itll fit . a mate just used a 4x4 rear beam on his saph
Old Mar 11, 2005 | 08:36 PM
markk's Avatar
markk
if youve got a 2wd cosworth now , and your converting it to 4wd leave the back end exactly how it is
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
mpilk
Sep 27, 2015 09:21 AM
