lambda sensor
Old Dec 23, 2012 | 12:35 AM
lukewhite's Avatar
lukewhite
Default lambda sensor
hello i have recently bought st170 and engine light came on within month of having it got it checked and was lambda sensor bank one so changed that. Now engine light is back on sane fault code has come up any ideas what else could be causing this to happen ?
thanks luke
Old Dec 23, 2012 | 06:48 AM
oldford's Avatar
oldford
What's the number of the fault code? And the exact description?
Old Dec 23, 2012 | 09:07 AM
lukewhite's Avatar
lukewhite
the fault code is p1131 not sure on description didn't take notice sorry
Old Dec 23, 2012 | 09:30 AM
oldford's Avatar
oldford
P1131 - Lack Of HO2S11 Switches - Sensor Indicates Lean
This is probably NOT a failing Oxygen sensor, but a lack of fuel in the engine.
Could be an air leak or a faulty sensor.
It can also be caused by a low fuel pressure, maybe a blocked fuel filter?
Old Dec 23, 2012 | 09:46 AM
lukewhite's Avatar
lukewhite
ok thankyou will look into them
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
