Cossie management no spark
Old Dec 19, 2012 | 11:11 PM
RS-Rikki's Avatar
RS-Rikki
Default Cossie management no spark
Right I have re shelled my s2 adding l6 management. ATM when I turn the key there's a lot off clicking under bonnet but the fuel pump doesn't prime like it use to.
When I turn ignition 1 click I get a single spark on plugs then as the engines turning over I don't get a spark through the plugs. But if I have a plug in the king lead I get a spark .
It won't run and if I'm lucky it will start for a min n run like utter shit.
I have took the injector rail of and is spraying fuel also when I am turning engine over oh then does the fuel pump prime
This is the three wires that connect in the car.
I had real trouble trying to get this to earth
Old Dec 20, 2012 | 12:08 PM
martysmartie's Avatar
martysmartie
Have you misconnected the phase and CPS, during the re-shell?
Martin
Old Dec 20, 2012 | 03:16 PM
RS-Rikki's Avatar
RS-Rikki
Would be almost impossible as both completely differnt sides of the engine plus when the injector rail was of injectors where pulsing so trigger wheel functioning properly ?
Old Dec 20, 2012 | 03:24 PM
martysmartie
Ok, just a thought, as these can be misconnected on a YB!
You don't have a 36-1 trigger do you?
Martin
mk3ste
Oct 17, 2021 10:09 AM
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
griffo69
Oct 4, 2015 11:58 AM
deathrider666
Sep 28, 2015 06:12 PM
