Temp sender causing juddering?????
Old Dec 10, 2012 | 05:01 PM
beemer1664's Avatar
beemer1664
Default Temp sender causing juddering?????
My s2, when im in any gear and take foot of throttle whilst its still in gear it judders, do you think it could be down to temp sender!
Also there is slight misfire when first starting up am i right in thinking it could be an injector? If so how would you check
Old Dec 11, 2012 | 08:24 PM
beemer1664's Avatar
beemer1664
anyone
Old Dec 11, 2012 | 11:11 PM
black_jack's Avatar
black_jack
Black Jack
It may not be the temp sender but simply transmission slop/ driveline shunt
The misfire when 1st starting up may be electrical - EG - plugs or accociated components
Old Dec 12, 2012 | 06:51 AM
clyde 1800's Avatar
clyde 1800
my sierra needed a new temp sender and it idled ok and drove without throttle but when it was warm it was like kangarooo juice as is some one was turning the key on and off when you were driving along
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
IainRS1700T
Sep 25, 2015 06:44 AM
martynhomer01
14
Sep 23, 2015 12:23 AM
