s2 metering unit
Old Mar 7, 2005 | 05:37 PM
rs155's Avatar
rs155
Default s2 metering unit
the unit has fuel going to it so i know the relay is not knackard,
when you take an injector off the fuel is there but it does not seem to be
injecting it up the pipe..
there is loads of fule in the unit ...
any idea why the injectors will not inject the fule..
thanks..
Old Mar 7, 2005 | 08:20 PM
radiant red's Avatar
radiant red
there may be fuel but not enough pressure, the injectors require i belive around 2-3 bar. had a similer fault on mine, checked pressure and it was too low so i changed the pump, everything fine.
Old Mar 8, 2005 | 09:54 AM
rs155's Avatar
rs155
how did you check the pressure mate.
gingeRS
17
Oct 2, 2015 09:42 AM
Steve Escos
Oct 1, 2015 06:57 AM
A.t.p
Sep 29, 2015 05:04 PM
