Electric Windows!
Old Mar 7, 2005 | 12:24 AM
Poom's Avatar
Poom
Default Electric Windows!
Hi guys,
The leccy windows on my G plate ERST are so unreliable, the drivers side will open but then struggle to close and the passenger one opens slowly and is a bitch to get back up again!
Is this a common problem? Where should I start checking to get them working again?
Thanks
Poom
Old Mar 7, 2005 | 09:16 AM
Alvyn's Avatar
Alvyn
more than likely its the motors are knackered m8(new ones needed)! try spraying wd40 down the rubbers as that does helps them to slide up
Old Mar 10, 2005 | 08:16 AM
oriontrb's Avatar
oriontrb
mine did the same all i did was lube all the working parts behind the door card if that doesnt help then try new motors
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
stevecfrst1
Sep 30, 2015 05:18 AM
cossie330
Sep 27, 2015 04:13 PM
IainRS1700T
Sep 25, 2015 06:44 AM
