Mk4 Cabby Engine replacement
Old Sep 6, 2012 | 09:39 AM
pimmy's Avatar
pimmy
Default Mk4 Cabby Engine replacement
hi guys, wonder i you can give me some advice.
I bought a 1990 MK4 XR3i cabriolet which someone has fitted a 1.4 lump into. I have a replacement xr3i engine/gearbox to go in but was wondering
if it's possible to just replace the engine leaving the old gearbox/drivehafts in place or do i need to remove engine/box complete as it says in the haynes manual
Also if the engine and gearbox does need to come out complete can it be removed from the top or does it have to be dropped from under the car as Haynes recommend??
thanks in advance for any advice
Old Sep 6, 2012 | 10:06 AM
xr3man's Avatar
xr3man
I would swap engine and gear box together, so much easier, you would have to move gearbox anyway to get engine in,you would have to move this so much any way take out drive shafts aswell , just fit other engine and box, as for out top or bottom? have you a engine lift? if not,then out the bottom. jack up high on good axle stands. all it depend on is what tools and room you have.piece of piss once every things out of engine bay hope this helps
Old Sep 6, 2012 | 10:01 PM
johnnysash's Avatar
johnnysash
You can swap just engine. Remove bottom pulley and throw it in at an angle.... Happy days! Try not to scratch your inner wing though!
Old Sep 8, 2012 | 07:44 AM
no1birdman's Avatar
no1birdman
hi, so u can leave gearbox, driveshafts in car, remove pulley and out it comes, brilliant, is that same for a 1.6 diesel as well
j.hammond1
30
Oct 31, 2021 05:28 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
EoinXR3
Sep 7, 2015 05:44 AM
A.t.p
Aug 15, 2015 11:37 AM
Blown Hell
Aug 5, 2015 07:22 AM
