focus ghia 2002 again
Old Sep 2, 2012 | 10:36 AM
JAMSIE13's Avatar
JAMSIE13
Default focus ghia 2002 again
Hi Guys, you have provided some great answers so far, here is my next riddle, on my dash i cant see how much petrol i have, no mileage, no speed or temp guage readings, read manual changed 2 fuses both 7.5 amp for instrument cluster, now i have half petrol tank not going to zero when i switch engine off, temp guage goes to half then closes down when engine is switched off, still no mileage showing and the o/d button also not working,,,again many thanks in advance
James
Old Sep 2, 2012 | 09:41 PM
martysmartie's Avatar
martysmartie
It sounds like you have a faulty dash, this is a common problem and even had a "Watchdog" feature back in the day, as it has the exact symptoms you mention, bar the O/D button, and the fact it blew two fuses, tbh not knowing the Autos, I don't know what the former could be.
The only cure is to replace the cluster, unfortunately!
Martin
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
Tank Mike
Sep 26, 2015 08:07 AM
cliffy70
Sep 20, 2015 09:18 PM
Flateric_2002
Sep 15, 2015 08:41 AM
