T 34 Turbo Question
Old Aug 17, 2012 | 05:14 PM
MKcosi's Avatar
MKcosi
Default T 34 Turbo Question
I have a problem fitting a new Cossi engine with a T34 into my car
Problem is the boost pipe outlet faces more or less out sideways, i am very tight for room so is there any way to make it point more downwards, by rotating it in some way.??????
Old Aug 17, 2012 | 05:58 PM
danb21t's Avatar
danb21t
There are 6 13mm bolts that hold clamps onto the compressor housing, if you undo them you can rotate the housing.
You may need to rethink the actuator bracket though.
Old Aug 17, 2012 | 06:21 PM
MKcosi's Avatar
MKcosi
Thanks very much for the info
Matt Baxter
Sep 16, 2015 08:30 PM
s1turboman
Aug 29, 2015 04:27 PM
Marcus L
Aug 29, 2015 02:18 PM
A.t.p
Aug 15, 2015 11:37 AM
Michael Wisbey
Aug 14, 2015 11:57 PM
