Twin Dellorto 40 carbs. Help !!!
Old Apr 23, 2004 | 04:43 PM
Default Twin Dellorto 40 carbs. Help !!!
to cut a long story short, i was having problems with the car and me and my mate eventually got it down to a fueling problem.. so i fiddled with carbs so it got me home.Turned out it was an ignition problem. fixed that and the car ran like a bag of nails with a flamethrower attached.i recently bought a carb balancer that shows you the airflow so i managed to get the car drivable but it still aint pulling in the bottom 2500 rpm and it wont rev past 7000, before it could go to 8200. anyone with any knowledge on these carbs and lancia twin cam engines would be most appreciated. if not there is a specialist but i am a strong believer in persiverance.
Old Apr 23, 2004 | 11:23 PM
xr-stu's Avatar
xr-stu
this is what happens when you mess with carbs mate.
you need to get it to a garage with the proper equipment to set the fueling up again, you probably totally fucked up the mixture etc etc.
Nov 1, 2015 06:53 PM
sridgett
Oct 1, 2015 07:30 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
stevecfrst1
Sep 30, 2015 05:18 AM
