24v boa wiring into sierra
I was wondering if I could get a definitive answer for wiring up the 24v boa into a sierra as all I have found is check wiring diagrams etc..
My understanding from asking a few mates is that the boa engine loom fits straight in without needing to cut any wires (take from p/s down chassis leg, around headlight panel and back up d/s chassis leg for rest of plugs)
I was told then that there are only 9 wires needing wired up which I so far have narrowed down to live,earth,oil light,battery light,temp hand and rev hand.
Can anyone give me any guidance on this whether I am on the right lines and what else has to be wired?
I want as much info as possible before I set the engine in,
Thanks for any help and hopefully I am making sense
Hi I know this might be a long shot but wondering if could help me out
I currently had a very good old friend that was a very good car electrician that has passed away
very sad times I must say
he was in the process of wiring my loom into my Sierra
witch unfortunately hasn’t been completed
i was reading your your posts and seen you done this conversion
and would be very great full if had any info on this pls
many thanks
looking forward to hearing from you soon
mark
many thanks
mark
mike elsome
Sep 14, 2015 04:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
