Rs turbo wont start???
Old Aug 10, 2012 | 08:43 AM
nsdrst's Avatar
nsdrst
Default Rs turbo wont start???
I drive my Rs turbo 80 miles round trip everyday jus got to work after 40 mile trip switched it off and then got in it again drove down the road not even a mile switched off again then got in it after 5 mins and now wont start at all it's got Clifford g5 alarm and when I switch imobilzer off I hear the fuel pump running but when I turn the key nothing not even cranking ? Does anyone have any idea wat it could be ? I haven't had any problems with it before like I said I drive 80 miles everyday and no probs before now ?
Old Aug 10, 2012 | 10:25 AM
TommysKeeper's Avatar
TommysKeeper
Hot starter motor? Let it all cool down and try again. Good Luck
Old Aug 10, 2012 | 11:20 AM
Lennon's Avatar
Lennon
give the starter a whack with a bar or a bit of wood mate, usually works, if it keeps doing it get a diesel starter from an escort or mondeo there cheap at scrapyards. hope this helps
Old Aug 10, 2012 | 11:29 AM
zxevhbonus's Avatar
zxevhbonus
old school
you could have a look to see if the small wire has come off the starter i used to have an orion turbo it happened to all the time
Old Aug 10, 2012 | 06:26 PM
nsdrst's Avatar
nsdrst
Cheers lads yh I found out it the starter positive is all coroaded I jus replace the wire and seems to be fine now cheers for the help lads !!!
Bailes1992
Aug 16, 2015 07:14 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
rs_turbo_ant
Aug 8, 2015 11:11 AM
Bloody-Fox
Aug 3, 2015 07:48 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
