OFAB Wiring Loom Problem..
Hello Everyone.
Can anyone send me a wiring diagram of the OFAB loom? I need to know exactly what pin goes where from both the ECU plug and the EDIS module!!
Also i need to know what the hell does the Yellow with Green trace wire go to coming out of pin 2 on the EDIS? It also has been cut.
If someone can come up trumps with an exact wiring diagram to help me work out and make sure every pin is in the correct place on both the ECU and EDIS so i can re wire it to what i need it to do.
Thanks
Thanks
To cut a long story short i brought a OFAB loom & ecu off my mate as ive converted my ERST to EFI and before we splice the EFI loom into my loom i want to to check to make sure every pin is correct and the colour of the wires match up with the correct pin so that they run correctly.
Probably abit confusing mate i do apologise lol.
On a tangent
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
muz
Sep 30, 2015 08:29 AM
