3dr brake servo
Old Jul 31, 2012 | 05:23 PM
cos358's Avatar
cos358
Default 3dr brake servo
hi
the brake servo/accumalator has stopped working i bought a new unit but it turns out there is no power going to the pump, iv traced the relay to drivers side footwell there power to the relay but there doesent seem be an earth on the switching side, when i connect this to ground the pump runs pemanantly, does any1 have a diagram for the brake wiring diagram? or does anybody know where this relay is switched from??
any help will be much appreciated thanks.
Old Aug 1, 2012 | 11:31 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
Still got ABS?
What's the actual problem with the brakes?
Old Aug 2, 2012 | 12:57 PM
martysmartie's Avatar
martysmartie
It's tripped by a pressure switch, so I suspect there is something wrong with the wiring to this, or the switch itself.
The pressure switch is located on the master cylinder.
Martin
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
