starter wire question
Old Jul 22, 2012 | 03:17 PM
clyde 1800's Avatar
clyde 1800
Default starter wire question
no power going to the starter
where does this wire lead to?
car starts when i bridge the starter
i dont really want to put a push button in but i will if i cant find the problem
Old Jul 22, 2012 | 08:10 PM
cabriolet's Avatar
cabriolet
little wire? what car?
Old Jul 23, 2012 | 09:17 AM
clyde 1800's Avatar
clyde 1800
sierra twincam
has anybody got a wiring diagram?
Old Jul 23, 2012 | 12:38 PM
martysmartie's Avatar
martysmartie
It's just a live feed supplied via ignition pos 3, usually has a round black rubber connector which fits onto a stud on the starter?
Martin
Old Jul 23, 2012 | 06:32 PM
clyde 1800's Avatar
clyde 1800
could there be any breaks? i will have to take apart my dash again and follow it
ignition lights on but no power to the starter when turned full way
the starter is fine and a wire run from the spud to the battery turns over no problem
Old Jul 23, 2012 | 07:06 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
Have a look at the single plug just by the front of the battery tray, this is the starter solenoid wire from the car loom down to the starter. It could also be the starter inhibitor relay (not just on automatics like the Haynes book of lies says), IIRC, it is the big relay, front left of the fusebox. Mine quit the other day, it would crank if you flashed the starter direct from the battery but not turn on the key.
Old Jul 23, 2012 | 08:47 PM
martysmartie
An inhibitor switch is ONLY on automatics to prevent them starting in gear, the relay you refer to is the starter relay and something totally different.
Also I assume this was on a different car, as OP'S car does not have a starter relay.
Martin
Old Jul 23, 2012 | 10:24 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
Martin
Martin, it's correct that only the auto cars have the inhibitor SWITCH but manual DOHC cars from 1990 on have the same relay XII but it is fed from the EEC IV ECU instead of the inhibitor switch. I know earlier cars had a jumper in the fuse box and no relay.
Both of my 1992 manual cars have this relay, the estate is DOHC and the 2.9 twin turbo used to be DOHC.
The wiring diagrams in the Haynes book show the relay for auto or a jumper for manual and label the relay as Auto Trans Relay XII.
I'm not 100% on the position in the fusebox but relay XII is identified on the diagram in the fusebox lid.
Old Jul 24, 2012 | 06:59 PM
clyde 1800's Avatar
clyde 1800
i swapped all the relays with a sister car but no joy
but right enough you may be on to something with the switch for the automatics
see the car was pinto originally so i totally rewired the whole thing for a twincam engine every piece of loom was changed
the donor car was a twincam hatchback diff car that was wrecked and the engine had blown
it had a manual box in it but the sump was an automatic sump grinded back so the starter would fit
Old Jul 24, 2012 | 07:01 PM
clyde 1800's Avatar
clyde 1800
Size:  322.8 KBName:  adamsbb5712133.jpg
Size:  219.1 KBName:  adamsbb5712128.jpg
Old Jul 24, 2012 | 07:55 PM
martysmartie
That makes sense now
OP, so you think the donor car was originally an automatic, if so you probably bypassed the switch when it was converted, something you haven't replicated when moving the loom over, perhaps?
Martin
Old Jul 24, 2012 | 08:09 PM
clyde 1800's Avatar
clyde 1800
i bought the red car as a non runner and with a switch wired into the dash for the starter
so i dont think the man bothered fixing the problem where is this switch situated marty?
Old Jul 24, 2012 | 08:22 PM
martysmartie
If it was auto the switch would have been on the box itself, so is there any wiring around there?
If so you just need to bridge the connections.
Martin
Old Jul 24, 2012 | 08:28 PM
RichieST's Avatar
RichieST
What you could always do is run a new wire from position 3 of the ignition switch straight to the starter relay live trigger feed, thus bypassing any starter inhibitor switch etc.
Old Jul 24, 2012 | 08:34 PM
clyde 1800's Avatar
clyde 1800
id say theyve just disconnected the gearbox wiring off at the plug behind the engine
thanks for all the help folks id say the plug going to the car has maybe extra wires whereas the wire going to the gearbox doesnt
is this just a matter if cramping these extra wires together before the plug?
Old Jul 24, 2012 | 09:04 PM
martysmartie
Yes so as to complete the circuit, or as said run another wire, but personally I would want to sort the OE wiring.
Martin
Old Jul 24, 2012 | 09:14 PM
clyde 1800's Avatar
clyde 1800
thankyou i will try this after work tomorrow and post up how it goes
Old Jul 28, 2012 | 08:11 PM
clyde 1800's Avatar
clyde 1800
Old Jul 28, 2012 | 08:14 PM
clyde 1800's Avatar
clyde 1800
ok so thanks to you guys i found the problem
what i done was unplugged the gearbox wire and just as you can see eliminated one at a time trial and error
it turned out to be the brown matches to the brown with white stripe for anybody who has this issue in the future
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
marky_g
Sep 12, 2015 04:26 PM
cossie09
Sep 10, 2015 06:56 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
