S2 Cutting out after 15 seconds!!!!
Old Mar 3, 2005 | 08:05 PM
MK5RST's Avatar
MK5RST
Default S2 Cutting out after 15 seconds!!!!
It starts from cold find but after around 10 seconds is gets lumpy then totaly dies unless you rev it, ive posted a cpl of times but its been pushed down, perhaps the right people wernt on to answer? Just a quick reply is all i ask Im sick to death of this problem, cheeRS. pete
Old Mar 4, 2005 | 08:56 AM
escortrsmatt's Avatar
escortrsmatt
sounds like its running far too rich!! try disconnecting your cold start injector on the back of the inlet manifold!!hope this helps.
Old Mar 4, 2005 | 11:49 AM
velocity's Avatar
velocity
sounds like to much fuel at cold,as above disconnect the cold start valve and see how she behaves,
also check the throttle plate in the air cleaner box isnt sticking,ensure all the air pipes are secure,
how does it run when warm/hot?
Old Mar 4, 2005 | 05:41 PM
MK5RST's Avatar
MK5RST
Have unplugged it, no diferent, flap isnt sticking, it just kinda flaps open a little and closes every second when turning over then once running it stays open a fractio n, have checked plugs and they are clean?
Old Mar 6, 2005 | 01:25 PM
Windle's Avatar
Windle
mine did this when i ran a dump valve it was sticking open and casuing mass air leak. wortha try if you run a dump valve ?
Old Mar 6, 2005 | 02:45 PM
MK5RST's Avatar
MK5RST
Ill give that a try, it isnt as bad now but it pops and farts like a gud un!!
A.t.p
Oct 23, 2015 07:54 PM
Mark RS
Oct 12, 2015 06:01 AM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
