Cosworth idle
Old Mar 3, 2005 | 05:09 PM
ricky_3dr's Avatar
ricky_3dr
Default Cosworth idle
Why does my 3dr idle at around 1300-1400 rpm?
thanx in advance
Old Mar 3, 2005 | 05:11 PM
tkrath's Avatar
tkrath
Default Re: Cosworth idle
thanx in advance
Remove your foot from the pedal
Old Mar 3, 2005 | 05:31 PM
TIFF's Avatar
TIFF
Chasing Radders
Your idle is set to high
Old Mar 3, 2005 | 05:52 PM
Chris Honeywell's Avatar
Chris Honeywell
Yes reduce your idle sped to about 1k
then it will idle at about 1k
hope this helps
Old Mar 3, 2005 | 06:02 PM
D7AKE's Avatar
D7AKE
Have you done anything to the engine or has it just started to happen....?
An engine can idle faster hunting for more fuel on tick over especially when a filter has been assed for example where the Co would need adjusting then the idle can be turned down on the idle screw.
Si
Old Mar 3, 2005 | 06:45 PM
velocity's Avatar
velocity
a small air leak on the vaccum side of the butterfly,idle speed control valve faulty/dirty
idle speed set incorrectly,leaking diaphram on a dump valve,throttle not fully closed at idle,incorrect fueling, but to name a few
Old Mar 3, 2005 | 07:48 PM
ricky_3dr's Avatar
ricky_3dr
The thing is guys, when the car is cold it idles at 1k but when it get up to full operating temperature the idle rises to 13-1400 rpm I've checked for air leaks and all seems fine.
Old Mar 3, 2005 | 07:50 PM
ricky_3dr's Avatar
ricky_3dr
hope this helps
Thanks for that Chris, very usefull
Old Mar 3, 2005 | 07:58 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Water temp sensor, ISCV could be faulty or badly wired.
Mike should have a space ISCV of mine you can try.
Does disconnecting the ISCV when she's warm make a difference ? Revs should drop to base idle.
Old Mar 3, 2005 | 08:14 PM
richm's Avatar
richm
Ricky,
Let's start by assuming you've got no leaks,, (as you say you've checked )
Disconnect the idle valve and see if the idle drops - if it doesn't, remove the valve and seal off the hole in the throttle body with something appropriate. If idle drops now, then the valve is stuck open, if not then try and adjust the base idle setting with the bypass screw on the bottom of the throttle body.
If you can't adjust it down to 850-900rpm, then you HAVE got a leak somewhere between the throttle body and head.
Old Mar 3, 2005 | 08:15 PM
ricky_3dr's Avatar
ricky_3dr
I have'nt tried that yet, i'll give it a go tomorrow
Old Mar 3, 2005 | 08:27 PM
frog's Avatar
frog
Ricky, gimme a shout if you need a hand or something.
If she was idling fine before, it's either a leak or a sensor/iscv in my opinion.
The idle screw doesn't move on its own, I wouldn't touch it unless you are 100% sure everything else.
Seems logical to me, but I might be missing something
Old Mar 3, 2005 | 09:02 PM
Eagle's Avatar
Eagle
Super Moderator
i was gonna say the blue water temp sender .. as i had the same type of thing on mine..changed it and went back to normal
Old Mar 3, 2005 | 09:07 PM
frog's Avatar
frog
Oh, and I have one you can borrow to try if you want. But it would be best to check this at the ECU when car is cold and warm, cos taking them out is a fidldy job ( + you have to empty coolant IIRC).
Stu @ M Developments's Avatar
PassionFords Creator
Make sure your throttle cable isnt too tight and adjusted for "Max Power"
Old Mar 7, 2005 | 01:50 PM
ricky_3dr's Avatar
ricky_3dr
Thanks for the replies guys it turned out that the butterfly was sticking open a little too much
Nov 3, 2015 04:08 PM
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
15
Oct 7, 2015 03:43 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
