Help. 2wd Saph not boosting
Old Jun 28, 2012 | 04:03 PM
waynefrst235's Avatar
waynefrst235
Default Help. 2wd Saph not boosting
Hi folks. Posting on behalf of a mate. Fitted a replacement engine into his Saph but it is making zero boost. Stage 3 spec on a t34.48. We have tried the following:
3 different good turbos.....the t34.48, a t38 and a standard t3
2 amal valves and running it without
3 different MAP sensors, 2 are brand new
Blanking dump valve off
Plugged in L8 and L6 Ecus
The car has a brand new loom so in theory the wiring side should be fine
All boost hoses are new and tight
The engine runs fine, just makes zero boost. Piped a boost gauge in and it goes to -0.8 at idle and 0 under load
Any help or ideas would be appreciated
Cheers, Wayne
Old Jun 29, 2012 | 04:30 PM
Alvyn's Avatar
Alvyn
hole in intercooler? has the actuator been put on correctly?
Old Jun 29, 2012 | 08:26 PM
martysmartie's Avatar
martysmartie
Faulty actuator?
Martin
Old Jun 29, 2012 | 08:56 PM
orangerush's Avatar
orangerush
defo actuator cant really be anything else
Old Jun 29, 2012 | 09:02 PM
Sticky.'s Avatar
Sticky.
Run the car with no exhaust, baffles may have collapsed
Old Jun 29, 2012 | 09:08 PM
waynefrst235
Thanks for the replies folks
Spent a bit more time on it today and made a bit of head way
The guys that said actuator are half right, what we found was that the actuator bracket on the t34 was bent slightly out of shape. This meant there was barely any preload on the actuator. Swapped with a better bracket off a spare turbo and it has improved a fair bit
Still doesn't feel quite right for the spec though. Going to pipe in the boost gauge tomorrow and bypass the amal valve and see what happens then
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
155lee
Oct 27, 2015 04:55 AM
dojj
28
Sep 11, 2015 10:00 PM
