Clearing EML light on Ford Focus mk2
Old Jun 14, 2012 | 06:52 PM
blader1611's Avatar
blader1611
Default Clearing EML light on Ford Focus mk2
I read a few articles that said unplugging negative side of battery for half an hour should reset the EML but that didnt work for me, any ideas? i have ODB scanner but it doesnt seem to be clearing the codes.
Old Jun 14, 2012 | 07:01 PM
Carlos-Titx's Avatar
Carlos-Titx
Pull the KAM fuse out for a while and put it back in, should clear it. Fuse 26 I think.
Old Jun 14, 2012 | 07:03 PM
botters's Avatar
botters
competant bodger
or disconnect battery and touch the positive and negative leads together for a few seconds this will drain all current held in any ecu's and motors on the car
Old Jun 14, 2012 | 07:10 PM
duncans90's Avatar
duncans90
First question to ask is why is it on?? Have you read the fault codes or is it simply a decat issue?
In either case pulling fuse 26 for 30 mins or so will clear it but with a decat it will be back
Old Jun 14, 2012 | 07:46 PM
RichieST's Avatar
RichieST
Does the EML come back on straight away? If so I'd say the fault hasn't been fixed. Did you get a new lambda sensor?
Old Jun 15, 2012 | 09:49 AM
blader1611's Avatar
blader1611
RichieST, I havent got a new sensor yet. I was trying to clear the codes so i could fit a new coil and see if that was causing the sensor issue. also was going to unplugg one of the sensors to see if i had the right one.
Old Jun 16, 2012 | 12:54 PM
blader1611's Avatar
blader1611
According to the handbook fuse 26 is for the automatic transmission. i dont see a KAM fuse on the list, any ideas?
Ford Focus RS Parts for Sale.
Aug 18, 2015 05:25 PM
taylora1409
Aug 12, 2015 12:06 PM
