misfire/compression??
Old Jun 10, 2012 | 03:12 PM
Alvyn's Avatar
Alvyn
Default misfire/compression??
what could be causing this problem? cylinders 1 2 and 4 have 150psi and number 3 only holds 100 psi! maybe a bent valve is my guess?? the car is missing all way through the range!
Old Jun 10, 2012 | 06:05 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
Bent or burnt out valve and/or burnt out valve seat. Could also be too small a valve clearance from a jammed lifter, this will likely result in a valve or seat burning out if not rectified quickly.
