sapp cos non starter
Old May 27, 2012 | 04:01 PM
ballbag42's Avatar
ballbag42
Default sapp cos non starter
hi guys anyone have any idea were the ignition relay is located on a non lambda 4x4 sapp cos as i have no supply to the ecu [l8] when turning on the ignition also pins 1 and 19 should be earthed but show 12v when ignition on hhheeeeellllllpppppppp
Old May 29, 2012 | 07:05 PM
Ants's Avatar
Ants
revisiting the dark side
Just an addition.......... does anyone have any schematics for the wiring on the ecu and engine bay wiring?
I'm fairly sure that it's an earthing issue after an engine swap...... I've read somewhere that pins 1 & 19 on the ecu should be connected to an earthing point on the block?
Old May 29, 2012 | 07:06 PM
costina's Avatar
costina
Live long and prosper!!
ecu wiring found here
www.bigturbo.co.uk
Old May 29, 2012 | 07:19 PM
Ants's Avatar
Ants
Yh found that already ta!
Old Jun 3, 2012 | 09:55 AM
ballbag42's Avatar
ballbag42
still no joy anybody got any ideas apart from torch it lol
Old Jun 3, 2012 | 02:48 PM
costina's Avatar
costina
There should be 3 earth wires (brown) connected to the inlet plenum throttle bracket top bolt.
A.t.p
Oct 23, 2015 07:54 PM
cossie362
Oct 11, 2015 03:53 PM
`spotty
Sep 25, 2015 11:41 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
marky_g
Sep 12, 2015 04:26 PM
