sapp cos wont start
Old May 13, 2012 | 09:29 PM
ballbag42's Avatar
ballbag42
Default sapp cos wont start
hi guys got a 1990 4x4 with l8 ecu 330 set-up just been restored but fails to start it has no power to the fuel pump and no spark any ideas checked that the wiring to pumps fine and checked pump works with seperate power supply also have a power supply to the coil bit stumped really thought it might have been either the immob or alarm fault but isolated each one and still nothing is there anything in between the ignition and ecu that might stop both items?
Old May 14, 2012 | 03:19 PM
opposite lock's Avatar
opposite lock
From my research over the years on PF it sounds like it maybe a crank sensor problem . Have a search on here if needed as its a commonly discussed issue.
A re-wire of the fuel pump is a popular mod if not already done.
Old May 14, 2012 | 03:31 PM
martysmartie's Avatar
martysmartie
Start by looking at your CPS and that the ECU has power.
The coil has an independent switched feed, hence that has power.
Martin
Old May 14, 2012 | 08:36 PM
ballbag42's Avatar
ballbag42
cheers guys i will do the ecu does have power so i think cps will be a good bet thanks
Old May 22, 2012 | 05:44 AM
SS1's Avatar
SS1
Does the engine turn over but fail to start
On the late 4x4 cosworths there is a fuel cut out switch in the drivers side kick panel
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
stevierob
Sep 7, 2015 07:09 PM
kevin36
Sep 2, 2015 06:24 PM
