puma conversion problems
Old May 11, 2012 | 06:52 PM
e18rly's Avatar
e18rly
Default puma conversion problems
ive recently bought a mk4 1.2 fiesta with a blown engine (r reg analogue) and a 1.7 crashed puma (w reg digital) then i set about completely stripping both and put engine gearbox ecu fusebox both looms key barrel transponder in to the fiesta. i came to start it and its trying but the petrol isnt reaching the rail. im not a mechanic but thought this was a easy conversion to start to practice for a mk2
if any one has any ideas i would really appreciate it
ive already put perol in and bypassed fuel cut off
Old May 11, 2012 | 07:13 PM
danielson04's Avatar
danielson04
I know this sounds stupid but have you fitted the fuel lines correctly? It's defiantly something stupid if it's turning over.
Old May 11, 2012 | 07:43 PM
RichieST's Avatar
RichieST
Is the fuel pump priming when you turn the ignition on?
Old May 11, 2012 | 07:48 PM
lacey's Avatar
lacey
Check the fuel cut off switch down in the foot well as it prob had a knock somewhere along the line
Old May 11, 2012 | 07:51 PM
e18rly's Avatar
e18rly
i think ive got them on the right way not 100%
i cannot hear it but wasnt sure can i test it without taking the fuel tank out?
the puma had abs air con central locking and power steering the fiesta hasnt will this make a differance?
also this is a track car has no dash carpet seats blowers or anything
Old May 11, 2012 | 07:53 PM
RichieST's Avatar
RichieST
Turn the ignition on, you'll hear the pump whirr for about a second. If it doesn't then i'd be checking wiring to pump/relays etc.
Old May 11, 2012 | 07:58 PM
e18rly's Avatar
e18rly
ill check that tomorrow hopefully it will get sorted ill let you no thanks for the advice
Chas
Oct 5, 2015 07:13 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
jonnyenglish
Sep 21, 2015 07:31 AM
BENJAMIN_21
Ford Fiesta
Sep 17, 2015 08:58 AM
Ben26
Sep 3, 2015 07:55 PM
