zetec water system help
Old May 5, 2012 | 07:50 PM
16vzetec's Avatar
16vzetec
Default zetec water system help
ive ditched the heater matrix in my car so ive got to do something with the water pipes that go into it.
i was thinking that if i just connect them together the hot water will just run straight through and back into the engine without going through the front rad.
so can i just block off the pipe from the thermostat housing so all the water goes through the front rad or will this create pressue issues?
Old May 5, 2012 | 08:09 PM
snoopaloopa's Avatar
snoopaloopa
Just join them together, the water won't know the matrix is missing lol
Old May 5, 2012 | 08:22 PM
16vzetec's Avatar
16vzetec
will it not be better if the water was cooled instead though as it will be used on track?
Old May 6, 2012 | 08:57 AM
snoopaloopa
It will still be cooled through the rad mate, you could always fit an uprated rad if you were worried about it.
Old May 7, 2012 | 06:43 AM
16vzetec's Avatar
16vzetec
Its not still cooled by the rad. it comes out of heater matrix and into front drivers side hose back into block. im thinking of blocking off all holes and taking the thermostat out so its straight through system
Old May 7, 2012 | 06:46 AM
Rollinz's Avatar
Rollinz
as you said, remove the pipe and block them off,
simple
Old May 10, 2012 | 08:46 PM
16vzetec's Avatar
16vzetec
i now want to ditch the thermostat housing completely, i noticed its quite heavy and im into lightweight so looking at ways of having a straight through housing with no thermostat as the car wont really be used when cold
Old May 10, 2012 | 08:59 PM
nevsrevs's Avatar
nevsrevs
could chop about a cvh housing?
SMILER258
Sep 28, 2015 09:04 AM
coscor86
Sep 20, 2015 01:21 PM
