Tapping Cosworth Part III
Old Feb 28, 2005 | 05:51 PM
nikh667's Avatar
nikh667
Default Tapping Cosworth Part III
Hi all - come to a point now in the new year to have another go at this faint tapping noise on my 4x4 (see https://passionford.com/forum/viewto...apping+lifters for previous!)
I'm going to remove the cyl.head firstly and thoroughly go over all the checks - distortion, check for wear in tappet bores, check valve guides etc..etc..
I've been wondering recently whether the noise is being caused by very faint touching of the valves against pistons - will be fairly obvious once i've got everything off, and i can measure the head height accurately.
Anyone ever had experience of this before? Not enough to cause damage but just the faintest of contact sufficient to cause a noise as the engine slows back to idle?
Old Feb 28, 2005 | 06:11 PM
Stu @ M Developments's Avatar
PassionFords Creator
Rattling on overun just before idle is often little ends rattling or loose piostons.
Old Feb 28, 2005 | 06:18 PM
nikh667's Avatar
nikh667
Thanks Stu, smart idea to get the whole lot out instead then, had considered those also, just going through all the possibilities - nothing better than advice from others who have experienced it. Cheers.
Old Feb 28, 2005 | 06:30 PM
nikh667,
Apart from perhaps someone else paying for the cure
Old Feb 28, 2005 | 06:58 PM
nikh667's Avatar
nikh667
Damn right - bottomless pockets req., lottery win would come in handy too.
One point - generally get normal tap from lifters from cold for a second or so - this second noise only occurs AFTER lifters has quietened down - hence led me to think that - lifters fill with oil - valves open more - and then make slight contact.
Anyway, if I rebuild the lot then i'll eliminate it either way - so irrelevant really. Your advice is enough for me not to risk just head work.
2 lucky dips this week........
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
3dr cossie
11
Dec 21, 2015 03:38 PM
Aug 14, 2015 07:29 AM
M K
Aug 12, 2015 06:57 PM
