Bet this gets you thinking!
Old Apr 19, 2004 | 07:36 PM
Default Bet this gets you thinking!
OK.
The story so far..........
Put a 89 rwd saff engine in sssc stylus kit and added 330 kit.
all was sweet for a year and then it started suffering from an occasional missfire on right hand bends on track( which i thought was fuel starvation cos it was only in rights). then it started to happen occasionaly at any time and felt like it was firing on only two cylinders. There was no pattern anymore - just where and when it felt like it.
Started it after a winter lay off and it fired straight into action ready to scare the pants of superbikes for another summer. Next day it needed turning over a couple of times to start - next day it needed turning over loads - next day it wouldnt start.
I have disconnected the coil lead from the distributer and have been observing the sparking:
Turn on ignition and a weak spark. Turn engine over and 1 sometimes 2 good strong sparkes then nothing appart from an occasional very weak spark but this is very rare.
Took injecters out and only 2 and 4 are working.
I have changed the following so far.....
Coil
Amplifier
ECU (but not chip)
ECU relay
had crank sensor checked
phase sensor
rotor arm
dizzy cap
leads are ford appart from coil to dist which is unipart
Matt recommended checking earths on inlet manifold which i did today.
Does anybody have any idea what to check next?
Advanced thanks.
Old Apr 19, 2004 | 07:51 PM
starturbo's Avatar
starturbo
Yeah.Try and make sure there are no bikers nippin in your garage of a night and playin with yer motor.
Old Apr 19, 2004 | 10:26 PM
spark plugs?
Old Apr 20, 2004 | 11:24 AM
Dont think its plugs Delta452, cos theres no spark frpm the coil.
Lol starturbo,
Old Apr 20, 2004 | 11:25 AM
Dave Henshall's Avatar
Dave Henshall
if only cornering hard round right hand bends - sounds like the oil surge is being blown up the factory breather and into the airbox, being digested by the engine and causing misfires - have you got a proper breather oil/seperator fitted so that the block can breather from both sides ?
Old Apr 20, 2004 | 11:40 AM
Dave Henshall, initialy the problem was only on rights but soon started to do it in any situation even on first start up. I dont have an airbox and have improved breathing from both sides. Thanks anyway.
Old Apr 20, 2004 | 05:13 PM
Gav Diamond's Avatar
Gav Diamond
Have you tried checking the loom?
Old Apr 20, 2004 | 08:10 PM
ML's Avatar
ML
Chip
Old Apr 20, 2004 | 09:33 PM
Hi Matt - if you got those crank sensors in i will have one off you tomorrow. trying a chip in it tomorrow as well so fingers crossed. If its ok then i want stage 3 please.
Cos500
Sep 15, 2015 06:47 PM
gcfcos
88
Sep 15, 2015 03:48 PM
xrmalin
Sep 13, 2015 06:52 PM
markk
Sep 9, 2015 08:11 AM
