Cossie crank
Old Nov 1, 2003 | 05:27 PM
Toe Knee's Avatar
Toe Knee
Default Cossie crank
Anyone know the big end and main journal sizes for a cossie crank?! Gotta order some shells for mine and just measured em with a digi caliper and the mains are 57mm bar the odd .something variance, and the big ends are 52mm .something variance lol.
Tony
Old Nov 1, 2003 | 05:55 PM
Guinnless's Avatar
Guinnless
Old Nov 1, 2003 | 06:01 PM
Toe Knee's Avatar
Toe Knee
You coulda bloody cleaned it!!!
Cheers mate
Old Nov 1, 2003 | 06:29 PM
Guinnless's Avatar
Guinnless
It's a proper manual! No cheque book repairs here
Old Nov 1, 2003 | 06:34 PM
Toe Knee's Avatar
Toe Knee
odd thou, the main in the manual says 56.989 and the 1 i measured came out at 57.05 and the big end 51.977 and mine was 52.17
Guess there will be a slight variance with all of em, but from that guess it'll be standard size shells for me!!
Old Nov 1, 2003 | 06:59 PM
Guinnless's Avatar
Guinnless
Your vernier caliper is probaly slightly out. Use a mike instead
Don't forget to check the bearing clearances with plastigauge and check the bearing 'crush' too (don't want any spun shells)
Old Nov 1, 2003 | 07:03 PM
Toe Knee's Avatar
Toe Knee
Well its a brand new digi caliper so should be pretty accurite!! Will measure each journal properly before i order the shells, whats a plastigauge?!
Old Nov 2, 2003 | 09:14 AM
Guinnless's Avatar
Guinnless
It's calibrated wire filaments that when sandwiched between the bearing shell become squashed. You then measure the width of the squashed wire and it gives the clearance.
It's a lot easier to use than to explain
Old Nov 2, 2003 | 09:56 AM
richm's Avatar
richm
a nice clean one any better ?
Old Nov 2, 2003 | 11:53 AM
Guinnless's Avatar
Guinnless
Bufty
Old Nov 3, 2003 | 11:16 PM
Toe Knee's Avatar
Toe Knee
Cheers peeps
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
