2wd to 4x4 conversion advice
Old Feb 27, 2005 | 03:36 PM
tenpotturbo's Avatar
tenpotturbo
Default 2wd to 4x4 conversion advice
got an f plate 2wd saph and want to convert to 4x4 am sorten on engine and front end but do i need to do anything to rear beam diff or rear suspension set up
Old Feb 27, 2005 | 07:40 PM
foreigneRS's Avatar
foreigneRS
Testing the future
only make sure that the rear diff runs an appropriate ratio for the front diff.
you also need to modify the floorpan to take the transfer box
Old Feb 27, 2005 | 09:22 PM
rosco's Avatar
rosco
if your sorted with the front end stuff just get the rear diff from the same car. the 2wd runs 3.9 and the 4wd runs 3.6. otherwise you'll need a chain step off that goes in the transfer box.
Old Feb 28, 2005 | 06:23 AM
tenpotturbo
cheers lads
Old Feb 28, 2005 | 08:03 AM
Nick500's Avatar
Nick500
This is not true mate, the 2wd cossie runs the same ratio diff 3.64 as the 4x4 rear diff which is also 3.64! the only difference is the sizes the 2 wd diff is 7.5" and the 4x4 is 7"!!
Nick
Old Feb 28, 2005 | 12:17 PM
tenpotturbo
which diff would be best mate
Old Feb 28, 2005 | 12:40 PM
Nick500's Avatar
Nick500
Using the 2 wd rear diff would be best as it is just that wee bit stronger!
Nick
Old Feb 28, 2005 | 01:01 PM
rog's Avatar
rog
Will it go straight onto a 4x4?
Old Feb 28, 2005 | 04:45 PM
tenpotturbo
so i can stay with 2wd diff and will 4x4 gearbox need to use which prop shaft 2 or 4x4 one
Old Feb 28, 2005 | 06:00 PM
Nick500's Avatar
Nick500
You will have to use the prop shaft forward of the 4 x 4 as they are compatible!
Nick
Old Feb 28, 2005 | 08:22 PM
abdr500's Avatar
abdr500
sorry to steal the post but does any one have any photos of wich part need welding or cutting or makeing to turn a 4x4 in to 2wd as i was told will need to make a braket for the gearbox to bolt up to the body or is this wrong thanks
Old Mar 1, 2005 | 08:02 AM
the original's Avatar
the original
i would recomend converting to vented rear brake set-up like on a 4x4 as you won't have the engine braking the rear wheels only, so they wil get that bit hotter
Old Mar 1, 2005 | 08:43 AM
foreigneRS's Avatar
foreigneRS
Testing the future
abdr500,
this pic shows the 2wd gearbox x-member as fitted to a 4x4 floorpan. where the x-member should bolt to the floor there is a space for the transfer box
to make it fit, bolt a length of 50mm box section onto the one mounting place that extends forward to make a mounting place for the x-member.
Old Aug 30, 2009 | 09:10 PM
forevaford's Avatar
forevaford
umm, im just converting my 4x4 saph to 2wd this weekend and came accross this gearbox mount problem, do you have to weld the box section to the floor pan?
Old Aug 31, 2009 | 09:00 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i bolted it up using the original mounting bolts but the nuts are a bit fiddly to get to inside the box section. it was so long ago now though that i can't remember what i did exactly. i think i cut the box at an angle at that end.
FlashRS
Sep 14, 2015 12:36 PM
mint_s2
Sep 2, 2015 08:58 AM
FlashRS
13
Aug 31, 2015 06:02 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
Old ford
Jul 31, 2015 06:50 AM
