converting an eecIV inlet to weber
Old Feb 27, 2005 | 02:49 PM
the original's Avatar
the original
Default converting an eecIV inlet to weber
how have you done this?
obviously the main difference is that the brown air temp sensor needs fitting....
are bosses available to be tig welded in?
any other mods needed?
cheers
Old Feb 27, 2005 | 03:37 PM
the original
ok i have just taken a look.
when using a 2wd throttle body the lug of the throttle pot touches the casting so i relieved both lightly with a file...
also the std breather system 'one way valve' cannot be fitted on the end of the plenum cover so also needs a boss put in...
fuel rail fittings are same as 4x4 sapphire but it looks as if a 2wd rail will fit if the extra lug provided is driled/tapped in the correct position.
anyone got any pics of their modded plenum covers?
Old Feb 27, 2005 | 10:38 PM
davi's Avatar
davi
I've got a small turbo one the only difference is i got a boss welded on for the act senser and drilled the spare lug to fit 2wd fuel rail.
Nov 1, 2015 06:53 PM
sridgett
Oct 1, 2015 07:30 PM
Fudgey
21
Sep 30, 2015 06:19 PM
mondeomark
Sep 28, 2015 06:28 AM
