cossie capri conversion
Old Apr 5, 2012 | 10:36 PM
paulyk's Avatar
paulyk
Smile cossie capri conversion
hows it going new to dis site im in da middle of doing a cosworth coversion into a capri and was wondering if any body could help me out cause im stuck on trying to get da car to spark if anybody has and info or has done 1 of dem any help welcome cheers
Old Apr 5, 2012 | 10:41 PM
lee2cossies's Avatar
lee2cossies
Converted mine to yb turbo. Do u mean yb turbo Cossie or 24v Cossie? It could be loads of different things causing it not to spark, first off I'd make sure it's wired tidy and getting 12v to the coil, then fuel injector and pump relays have fuses that kill the spark also.
Old Apr 5, 2012 | 10:47 PM
paulyk's Avatar
paulyk
yeah its a yb turbo dont no much bout dem meself and it is getting da 12v to da coil i didnt take much of da loom out of da sierra ownly da bit from da engine to da ecu with da few relays and fuses on it petrol pump is workin aswell der was 5 spare wires free on da loom that i had to hard wire in
Old Apr 5, 2012 | 11:00 PM
lee2cossies
Sounds like you've wired it up right then it's only them 5 wires u need. Check that the Amal valve boost control solenoid is clicking on second turn of key, if so then u have power to pump and ignition so points to crank sensor, phase sensor or ecu,or possibly distributor timed up wrong. If the Amal valve doesn't click then it's either the 2 relays or 2 fuses normally at fault.
Old Apr 5, 2012 | 11:11 PM
paulyk's Avatar
paulyk
is that boost control solenoid that sits on top of da front mount how do i go about phaseing da crank sensor or da ecu or to check if da distributor is timed up wrong cheers and befor i took da engine out of da sierra it was running mint
Old Apr 6, 2012 | 05:39 PM
paulyk's Avatar
paulyk
i checkd da boost solenoid and it is clickin on da second turn of da key and i took da ecu of da loom den phased all da pins in da connection and got power in two of dem da rest i havnt a clue how to do dem can any 1 help me please and thank you
Old Apr 7, 2012 | 10:32 PM
paulyk's Avatar
paulyk
can anybody help me with dis need ta get the car runnin
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
SMILER258
Sep 28, 2015 09:04 AM
