mixture adjustment screw direction
Old Apr 2, 2012 | 04:14 PM
enduro.nick's Avatar
enduro.nick
Default mixture adjustment screw direction
hi
my 1.6 cvh is running supper rich and im going to try and get it sorted this weekend but i am just trying to find out which way the mixture screw turns to make the car run a bit leaner? clockwise or anti clockwise? i can find all the othe information about it apart from this one little bit does anyone know???
Old Apr 2, 2012 | 05:22 PM
GVK.'s Avatar
GVK.
1.6 CVH is a bit vague..
Is it carb, injection?
What car is it?
Old Apr 2, 2012 | 05:36 PM
enduro.nick
sorry its from my mk 3 escort and its on the carb. im never good with the details
Old Apr 2, 2012 | 05:39 PM
GVK.'s Avatar
GVK.
Ah,the good old VV carb
Must be 20 yrs since I worked on one of those!
Exploded view here
A Top cover
B Manual choke unit
C Lever housing
D Choke cable bracket
E Automatic choke unit
F Bi-metal housing
G Air control vacuum
diaphragm housing
H Air control diaphragm
J Accelerator pump
diaphragm
K Accelerator pump cover L Throttle linkage
M Mixture adjustment screw N Anti-run-on valve solenoid P Idle speed adjustment
screw
Q Fuel needle valve
R Float bracket
From vague memory should be anti clockwise to lean mixture.
Check the choke isn't stuck on, and check the throttle diagphragm.
If you take off the airfilter, the variable part of the venturi (hence VV) should have resistance on it when you slide it back, if not the rubber diagphragm can be split or gone all 'sticky'
Also worth checking the accelerator pump diagphragm is not split as well.
Parts from here..
http://www.classicsagogo.co.uk/cgi-b...d.html%23aDVV3
Old Apr 2, 2012 | 05:58 PM
enduro.nick
thats awesome thanks for the help
bring on the 4 day weekend so i can get busy
Fezman1
Oct 2, 2015 01:22 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
Flatlinedan
Sep 18, 2015 12:41 PM
