oil return too low, viable fix?
Old Mar 28, 2012 | 09:45 AM
big_wig_074's Avatar
big_wig_074
Default oil return too low, viable fix?
im getting a car tomorrow that apparently smokes on boost due to its oil return being too low in the sump, causing the oil to back up the return line and come out the back of the turbo, now i know that the proper fix is to blank off the return and put another in the sump higher up, but, i was just wondering if i could fix the issue by fitting a tank in the return line? such as a breather tank so the turbo returns to the breather tank which then returns to the sump, giving enough additional volume to stop the oil returning back up the pipe?kind of an extra sump.
thoughts?ive not got any problems changing the location if required but its a lot of extra work if the above would work.
thanks
Old Mar 28, 2012 | 04:29 PM
markk's Avatar
markk
put a pump on the oil return line - that what we do on the bikes
Ian1964
12
Jan 26, 2021 11:57 AM
155lee
Oct 27, 2015 04:55 AM
Tank Mike
Sep 10, 2015 07:56 AM
andrewmctiernan
Sep 8, 2015 03:05 PM
hopper350
Sep 4, 2015 12:53 AM
