compression ratio
Old Mar 8, 2012 | 11:23 AM
Phil2002's Avatar
Phil2002
Default compression ratio
I want a new chip for my saff but am unsure of compression ratio can i find out the compression ratio with a compression tester?
cheers,
Phil
Old Mar 9, 2012 | 01:51 PM
opposite lock's Avatar
opposite lock
No i dont think you can hopefully this can be explained properly by people who understand it.Compression Ratio afaik is the relation between the amount of volume or 'squish area' when a piston is a TDC and the amount of volume there is once the piston is at BDC. So if your TDC 'squish' area is say 50cc and your BDC volume is 400cc the ratio is 8.0:1. Measuring the cylinder compression in PSI or BAR may well(possibly) show a low comp engine but as for working it out i,m not sure if its possible.I like stuff like this but only as an enthusiast who thought he,d have a wee go at answering lolpmsl. If its near standard YB then its most likely near standard compression which on a YB is 8.0:1 ish
Prickly_buzz
Dec 7, 2017 09:52 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
