clutch help
Old Feb 24, 2012 | 04:17 PM
v8saff's Avatar
v8saff
Default clutch help
hi people right im haveing problems with my clutch . its a new clutch 2wd standard i think at first it was slipping when replace then it seemed to be ok after a while now the clutch has only done around a 1000 miles i set off in her today quite quick an lost the traction gave it a bit an tried to drop it into 2nd an i got the rachet an no drive an now you can put it into gear put the power on an no movement .
i have changed the cable an still the same
the car is only runnin 20 psi an on a t34 on greys this will be goin up an bein set to a tuner soon so what clutch would you use.
Old Feb 24, 2012 | 04:19 PM
rs tingle's Avatar
rs tingle
ooops my fault i shouldnt have launced it sorryyyyyyyyyyyyyyyyyyyyyyy
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
