Hi guys got in car this morning drove 500 yards touch break pedal on snow and abs kicked in and the abs light ,traction control and hand break fluid light also came on and won't go out any ideas ,also abs don't work now ,cheers Karl
Take it you tried the usual disconnect battery for half hour?
have you got a fault code reader?
Hey up pal yes disconnected the batty and had it on machine ,came up with egr valve that was it and today noticed that turbo dint seem to be coming in so had a look under bonnet and the pipe to egr valve had split did this and running ok now but lights still on abs ,traction control and handbrake light
I think you need a better machine to read the codes from the ABS.
iv had it read on a very expensive machine coming up with nothing,could be sensor, wheel bearings there noisey could it be play in them be cause of when i broke ???????
