Tremec tko to yb
Old Jan 23, 2012 | 09:33 PM
Alg1k's Avatar
Alg1k
Default Tremec tko to yb
Is there an adaptor plate available to fit this box using the original yb bell housing,
Old Jan 23, 2012 | 09:36 PM
flannigan's Avatar
flannigan
No you have to modify the std bell housing to fit the gearbox
Old Jan 23, 2012 | 09:48 PM
Alg1k's Avatar
Alg1k
Do you know how or if anyone does it
Old Jan 24, 2012 | 03:15 AM
Gav Diamond's Avatar
Gav Diamond
Martin Hadland did mine for me
Old Jan 24, 2012 | 05:31 AM
Alg1k's Avatar
Alg1k
Cheers gav
Is it just a fact of redrilling the mounting
Holes in the correct place LOL
Or is there more to it ?
Old Jan 25, 2012 | 03:57 AM
Gav Diamond
Daz,
There is more to it bud, welding is needed as you need to add some lugs as the mountings are wider on the Tremec than what the T5 bellhousing is
You also need a spacer plate too between the gearbox and bellhousing.
Also you have to run a smaller bearing in the crank as the input is larger.
Not the best pic but best I have on my computer, here you can see the added on tabs for the fitting on this side
Old Jan 25, 2012 | 05:56 PM
Alg1k's Avatar
Alg1k
Cheers Gav
I have to GM version though,
I dont know if this is much different to the ford one ???
which i suppose you have ..
Old Jan 25, 2012 | 09:39 PM
jon@work's Avatar
jon@work
The GM version has a shorter input shaft and it's smaller diameter, so will fit into the
standard spigot bearing.
Old Jan 26, 2012 | 08:59 AM
Alg1k's Avatar
Alg1k
Jon
If its shorter won't I need to make the belhousing shorter
To suit. cut and shut ??
Old Jan 27, 2012 | 07:57 PM
Alg1k's Avatar
Alg1k
Anyone else with any info ?/
Old Jan 28, 2012 | 01:53 AM
jon@work's Avatar
jon@work
If you PM me your e-mail address, I'll send you some files I've come across.
I've got the same box as you - my local machine shop has had a spare bellhousing for over a year now without them doing anything on it, so if you come up with a guaranteed mod to get the box to fit, let me know.
When I got my box, I had a long think about the best way to mod the bellhousing. Old document contents below:
What I’ve Got
TKO 600 Gearbox, part number TCET4618. GM spec gearbox.
Things to sort out/buy
Ford TKO nose length and spline length
input shaft bearing support for hydraulic clutch
prop yoke
prop length
clutch plate
T5 Bellhousing Problem
GM box differs from Ford spec TKO 600 gearbox by having a ½” shorter input shaft. The input shaft diameter, 16mm, is OK for the standard crankshaft spigot bearing, whereas the Ford spec input shaft diameter is too big.
For info, the T5 input shaft length is ~180mm long from mounting face of box.
Potential Bellhousing Solutions
1. Change the input shaft to a Ford spec one, and get the nose machined down to suit the spigot bearing. Weld two strips to the rear bellhousing face for the 4 mounting bolts, or buy a bellhousing already converted.
Issues: Cost of input shaft and bought converted bellhousing.
2. Machine 1 inch off the entire rear face of the bellhousing and replace it with a new face 15mm thick, machined to suit the input shaft central support and 4 box mounting bolts and welded to the T5 bellhousing. Reface new rear face after welding to ½” thick.
Issues: Ensuring correct alignment of gearbox to engine.
3. Do not fit the shitguard between the engine and gearbox. Machine 2mm from the from of the T5 bellhousing face. Also, machine 2mm from the rear face of the bellhousing. This would allow the gearbox to be mounted approx 6mm further forward than standard, meaning that there is approx 6.5mm (1/2” minus 6mm) less engagement of the input shaft into the crank (this looks to be OK). Two strips would still need to be welded to the rear bellhousing face for the 4 mounting bolts.
Issues: Input shaft is still approx 6mm too short (but should be OK)
Martin adds a 5mm spacer to the T5 bellhousing when using the Ford spec box
Old Jan 28, 2012 | 11:48 PM
Alg1k's Avatar
Alg1k
cheers Jon
Ford input shaft it is then ,
Make a new crank spigot in bronze or have the input ground down
Dont know if that will effect the case hardening of the input ?.
Old Jan 29, 2012 | 12:09 AM
jon@work's Avatar
jon@work
I know Brom used to replace the spigot bearing with a bush. Don't think he had any issues doing this.
Old Jan 29, 2012 | 09:56 AM
jon@work's Avatar
jon@work
Have you got a source for a cheap Ford input shaft? If so, it may be a better option for me too.
IainRS1700T
Sep 25, 2015 06:44 AM
MK MOTORSPORT
Apr 23, 2011 06:23 AM
f6cus
22
Oct 5, 2009 05:21 PM
abdr500
Feb 10, 2009 11:26 PM
escort700bhp
Jan 8, 2009 01:24 PM
