idle prob
Old Jan 22, 2012 | 03:51 PM
peco's Avatar
peco
matt
Default idle prob
hi can anyone help i own m6 escort cab 1.6 zetec when selecting gear it start to rev and stays high only way stop it is turn it off,i have checked pipes all ok change idle valve ,postion sensor and throttle body and even cleaned ox sensor,plus replace temp sensor but still play up plz any help?
Old Jan 22, 2012 | 04:13 PM
martysmartie's Avatar
martysmartie
Clutch pedal switch? (If applicable), it is only when you go to select gear?
Martin
Old Jan 22, 2012 | 04:15 PM
peco's Avatar
peco
matt
hi sorry forgot say it auto
Old Jan 22, 2012 | 04:17 PM
peco's Avatar
peco
matt
it only happens when select drive it ok in reverse
Old Jan 22, 2012 | 04:22 PM
martysmartie
Oh right, it has to be some sensor on the box then, I don't know much about Auto's, but something relating to it must be telling your idle valve to open.
Martin
Old Jan 23, 2012 | 08:14 PM
johnnysash's Avatar
johnnysash
I had same problem on manual fez of similar vintage. Bit of a bodge but try unplugging road speed sensor maybe?
gcfcos
59
Oct 6, 2015 05:04 PM
fordrallycar
Sep 30, 2015 07:57 PM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
