Help
Old Jan 21, 2012 | 01:38 PM
Loucop's Avatar
Loucop
Question Help
I've got an 05 plate Mondeo TDCi which doesn't always like starting.
Sometimes it starts perfect and runs fine, but other times it will start and cut out, or it feels like it is about to stall and won't rev?? After about 30 seconds to a minute it seems to settle and runs perfect
Old Jan 21, 2012 | 05:37 PM
Brendan's Avatar
Brendan
struggling with reality
glow plugs ?
Old Jan 21, 2012 | 07:10 PM
Loucop's Avatar
Loucop
Well it only does it half the time, the engine management light comes on when it does it so I'm gonna hook the code reader up to it and see if there's any codes. Glow plugs should come up, I don't think it's them though coz they packed in on my other car and it was totally different. It starts initially, but either cuts out or won't rev :S
Old Jan 21, 2012 | 07:18 PM
bobster1982's Avatar
bobster1982
check the pump pressure on the code reader
Old Jan 21, 2012 | 08:32 PM
Loucop's Avatar
Loucop
Cheers, I would, only problem being I can't find the diagnostic pin plug? I've looked in all the usual places, is it worth pulling the driver's side mini glovebox out? would it be behind there?
Old Jan 22, 2012 | 07:34 AM
oldford's Avatar
oldford
Officially the diagnostic plug has to be around the steering wheel.
You must be able to reach it when seated behind the steering wheel.
O.K., you are supposed to be acrobatic some times.
See: https://passionford.com/forum/genera...ml#post5663604
Old Jan 22, 2012 | 03:26 PM
Loucop's Avatar
Loucop
That's really helpful, cheers mate
Old Jan 22, 2012 | 03:41 PM
CBenno's Avatar
CBenno
its on the bottom of the drivers side dash you have to slide it down as its tucked away
