cossy wiring
Old Feb 22, 2005 | 08:23 PM
mcgoo's Avatar
mcgoo
Default cossy wiring
got an escos wiring loom but the plug for the amal valve is missing, got a brown wire and a black/yellow wire, which goes to which side of the valve or doesn't it matter
Old Feb 23, 2005 | 09:09 PM
velocity's Avatar
velocity
are u sure u have the right colours for the amal valve the amal valve wire colours for a 93/93 ecos should be black and red, brown and yellow
acording to the wireing diagram i,m looking at
the only black and yellow wire i can see goes to the ignition module and also a wire to the insturment cluster,there does not appear to be any wire even going to the ecu with that colour code
Old Feb 24, 2005 | 06:05 PM
sailorbob's Avatar
sailorbob
Is it for a small turbo escort?
Usually the solid colour goes to to +12V and the striped wire goes to the ecu.
Fiesta turbo amal valves have a diode in them so they will only work one way, you could test the valve off the car to check it before commiting yourself.
Old Feb 24, 2005 | 07:08 PM
mcgoo's Avatar
mcgoo
sorry my mistake, it's an escos engine loom and 4x4 sierra ecu loom
Nov 1, 2015 06:53 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
