escort series 2 boost problem
Old Jan 18, 2012 | 06:17 PM
gazzas1982's Avatar
gazzas1982
Default escort series 2 boost problem
got a rs turbo run fine at 1.2 bar sent the turbo off to be rebuilt didnt know what stage it was so i had it built to stage 2 now its like there is no boost in first gear but there is in every other gear could my actuator need setting up as it was running 1 bar without the boost controller and now it runs just standerd boost 0.5 unless i adjust the boost controller so i aint 100 percent the turbo was rebuilt by cr turbos if that helps any help appriciated
Old Jan 18, 2012 | 06:26 PM
martysmartie's Avatar
martysmartie
It will run less boost without a controller as you arn't bleeding any, i.e. I presume you "hot plumbed" the compressor straight to the actuator?
I think it may be your actuator needs setting up as you say as there is no other logical reason why it would have changed.
CR Turbos are a reputable company so I doubt the turbos at fault
Martin
Old Jan 18, 2012 | 06:32 PM
gazzas1982's Avatar
gazzas1982
thats what i thought mate its the first time i have ever had a turbo built so i did look round and a lot of people said cr and the only thing i could think of is that the actuator aint getting enouth pressure to open properly in 1st gear
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
