Saying hello, and need help :-)
Old Jan 10, 2012 | 11:57 AM
bubba_1986's Avatar
bubba_1986
Default Saying hello, and need help :-)
Hey Guys
Just thought would introduce myself, new member to this site. Have a mk3 mondeo 1.8, 2000 plate. Just have as a run about.
Bought fairy cheap and changed the clutch, what a nightmare that was. Anyway when i put everything back together, there seems to be a connector spare ? .
If someone could possible point out where this goes i would be forever grateful, the engine management light is on and i suspect this is why.
Please see http://s1124.photobucket.com/albums/l580/bubba_1986/
Bubba
Old Jan 10, 2012 | 12:00 PM
2star's Avatar
2star
Does the car run okay? Do all other guages work on the dashboard?
Have you looked and or felt around the gearbox, looks like its off the engine, either inlet or thermostat housing area to me.
Old Jan 10, 2012 | 12:09 PM
bubba_1986's Avatar
bubba_1986
Hey, yeah the car runs fine, though is bit worse in fuel, my mate seem to think that is connects to something underneath as it is a very short connector. First thought the lambda, but that's connected. I mean that the other end of it is long and stretches up ???, confused.com
I intend to get underneath the car asap, to see, though weather ain't been to good. Was hoping someone might recognize it.
Thanks for the reply
Old Jan 10, 2012 | 09:26 PM
bubba_1986's Avatar
bubba_1986
anyone else have any idea ???
Old Jan 10, 2012 | 09:30 PM
GROUP A's Avatar
GROUP A
try youtube ? ive found some very helpful videos on there before ?
Old Jan 11, 2012 | 12:21 AM
bailey1981's Avatar
bailey1981
Find some one close by or go scrap yard & trace it back in the engine bay
or google it
cant be many green plugs
Old Jan 11, 2012 | 12:37 AM
2star's Avatar
2star
Its definately not off the black thermostat housing on the right hand side of the engine above the gearbox is it? could be water temp sensor hence the car is stuck in cold mode and using more fuel?
Its not off the reverse light switch or something daft like that? Have you checked the reverse lights work?
Old Jan 15, 2012 | 10:59 PM
bubba_1986's Avatar
bubba_1986
Thanks for all the replys guys. Turned out i had connected the blue plug for the second lamda sensor onto the first one at the manifold. The blue connector for one at cat was tiewrapped onto subframe and couldn't been seen from above. Right tit so i am.
On another note, bad knocking when braking and accelerating, thinking may be anti roll bushes.
any good ways to test?, subframe def tight, def not snapped spring(i replaced one )
droplinks tight, (new). calipers tight. anything else i am missing ??
Old Jan 15, 2012 | 11:22 PM
botters's Avatar
botters
competant bodger
is the lower gearbox mounting tight?
Old Jan 15, 2012 | 11:34 PM
2star's Avatar
2star
If it didnt knock before the replacement clutch then obviously its something not done up correctly. go through everything as if you were to change the clutch again and check.
Old Jan 16, 2012 | 05:34 PM
bubba_1986's Avatar
bubba_1986
Hey, yeah the lower gearbox mount was first thing i checked. It did knock when i bought it as spring was snapped, so hence bit confused. when u move the antiroll bar it is solid, though obviously i can't apply the same force as applied when braking.
Hopefully something simple, will let u all know if find out.
Thanks again
bubba
Old Jan 16, 2012 | 05:43 PM
martysmartie's Avatar
martysmartie
Are you aware of the of week point on these cars is the rear subframe/beam bushes, maybe worth a check?
Martin
Old Jan 16, 2012 | 10:58 PM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
either that ^ or you have some seriously fucked wishbone bushes, had one do that before
