Fiat Coupe brake brackets
Old Jan 9, 2012 | 04:32 PM
bobster1982's Avatar
bobster1982
Default Fiat Coupe brake brackets
Hi guys,
I have a Cougar that I am looking at fitting coupe 4 pot Brembos onto with either the ST170 300mm discs or the MK1 Focus RS discs onto.
The Cougars front knuckle is the same as the Mk2 Mondeo and I wondered if anyone on here can advise me on what needs machining off of the calipers to fit and also where to source the adaptor brackets from or a pattern I can use so I can make some up on the CNC at work. I don't mind paying for a pattern from someone but I think £80 for a set of brackets when they appear on Ebay is daft money for what they are.
Thanks,
Rob
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
