charging problem ?
Old Dec 11, 2011 | 01:47 PM
55rsturbo's Avatar
55rsturbo
Default charging problem ?
hi all having a bit of trouble, charge light was coming on now and again over bumps i think, put a new alternator on, somtimes the charge light does not come on at all even with just ignition on and then it comes on when you go along and then goes off, the AA man said there was no charge at all, so put the new alternator on, has any one had this problem or similar, perhaps there is some one who could point me in the right direction to solve this problem. cheers for looking. frankie. ps s2 turbo
Old Dec 11, 2011 | 01:57 PM
martysmartie's Avatar
martysmartie
Then his replaced something that was never broke!
The problem is almost certainly due to the "Thin blue" wire on the alternator has most likely been cooked! This is a critical part of the charging circuit and is the earth for the bulb light. Very common problem on these Fast Fords, thanks to the heat generated from the turbo!
Without this, you will have no charge unless you rev to around 3K+.
Martin
Old Dec 11, 2011 | 07:07 PM
55rsturbo's Avatar
55rsturbo
thanks marty will get that done weekend, will keep the car for ever so do not mind spending on new alternator, the wife does though. cheers frankie
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
jay030787
Sep 18, 2015 04:38 PM
Cos500
Sep 16, 2015 09:50 PM
