Cossie alternator
Old Feb 20, 2005 | 11:43 PM
Azrael's Avatar
Azrael
Default Cossie alternator
I had my alternator rebuild recently because rear bearing failed taking rear cover with it. I had those changed and everything reassembled. Still I get strange symptom when firing very cold car in winter freeze. It won't charge untill few seconds after starting or untill i rev it a bit... then it goes up from about 10V to 14V as it schould and light comes off. Durign drivng everything is fine. Is this on coming voltage regulator failure? or some other electronics? Or is this normal with Cossie alternator in low temps?
Old Feb 23, 2005 | 01:22 PM
Azrael's Avatar
Azrael
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
