Focus head light keeps blowing
Old Nov 22, 2011 | 07:45 PM
m1ke's Avatar
m1ke
Default Focus head light keeps blowing
I have a mk1 facelift focus on an 05 plate which is continually blowing headlight bulbs.. They are only lasting a few months and then blow again
To start with I just changed the bulb that had gone but then the opposite one would go shortly after and after about 6 bulbs I replaced the pair at the same time with Ring super bright bulbs which lasted around six months but one has now blown..
Is this a common problem, can't seem to find anything about it anywhere?
I have just stared using the heated screen again and wondered if this could cause a surge when turned off and would a resistor help?
Any ideas appreciated
Mike
Old Nov 28, 2011 | 04:38 PM
m1ke's Avatar
m1ke
I checked the voltage at the bulb when the screen was turned off and it jumps to 16 volts and then drops down again so I assume this is the cause of the problem.
Does anyone know which resistor I would need?
Old Nov 28, 2011 | 04:42 PM
RichieST's Avatar
RichieST
I'd be checking the voltage regulator on the alternator. Are you also getting 16 volts across the battery?
Old Nov 28, 2011 | 04:48 PM
m1ke's Avatar
m1ke
Didn't check that, will try it when I am at work tomorrow.. Thanks
Old Nov 29, 2011 | 12:29 PM
m1ke's Avatar
m1ke
Just checked and yes I am getting the same across the battery when the screen is turned off.. I assume this is pointing to the voltage regulator?
Old Dec 3, 2011 | 07:17 AM
Hobomassiv's Avatar
Hobomassiv
I didnt have a heated screen on mine and it did the same thing, usually ont he side behind the battery tray.
Old Dec 3, 2011 | 11:48 AM
jpm360's Avatar
jpm360
myold 52 plate focus zetec used to blow bulbs every month or so , in the end moving to bosch performance bulbs sorted it , i put it down to shit halfords bulbs in the end
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
jaysoc1
Aug 20, 2015 08:18 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
track.focus'd
Aug 12, 2015 05:53 PM
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
