Help with unreliable starter
Old Apr 12, 2004 | 06:23 PM
Default Help with unreliable starter
Hi,
I was wondering if anyone could help me with an ureliable starter.
From time to time, my sierra cosworth 89 2wd does not start.
I can hear the clicks coming from the relays but nothing from the starter motor. When this happens, if I leave the car for a while, it may start. Sometimes it starts after a few goes. When it does after this problem, the starter motor seems to cut out so I have to try several times before then engine catches.
Other timkes it starts perfectly.
Any ideas what could be causing this.?
Old Apr 12, 2004 | 06:30 PM
Check out your battery might be a loose connection there and then check all the connections to the motor too! Be carfull! High Voltage!!
Old Apr 13, 2004 | 01:13 PM
CabrioTurbo's Avatar
CabrioTurbo
loose/fucked connection on the starter solenoid is most likely causing it to click but not actually engage
CheeRs
Phil
Old Apr 13, 2004 | 02:00 PM
Thanks for the replies.
One thing I forgot to mention was that a lot of the times when I am driving the car judders. It seems like the egine cuts and goes again.
Maybe its connected. I am guessing this is a bad connection to the battery/earth that causes the bad starting and this ?
Old Apr 13, 2004 | 03:03 PM
Sounds like it!
A.t.p
Oct 23, 2015 07:54 PM
cossie362
Oct 11, 2015 03:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
marky_g
Sep 12, 2015 04:26 PM
