Cosworth electrical help
Old Oct 31, 2011 | 11:13 AM
MGZS1952's Avatar
MGZS1952
Default Cosworth electrical help
Hi anyone know the connections for ther ISCV I have pin 34 ecu to pin1 of the plug and pin 20 ecu to pin 1 plug
the other one im not sure of is the ACT 31 ecu to pin 1 plu and 11 ecu to plug pin 2
just need to know if thats correct for the p8 ECU.
thanks
Kev
Old Oct 31, 2011 | 11:52 AM
opposite lock's Avatar
opposite lock
http://www.bigturbo.co.uk/
hth
Old Oct 31, 2011 | 03:12 PM
MGZS1952's Avatar
MGZS1952
Thanks been there great for pin out for L8 ECU but dosnt actually tell you where the pins are connected to the plug/senor ends ie pin 1 or 2
thanks
Old Oct 31, 2011 | 03:28 PM
wes's Avatar
wes
ECU pin 34 goes to pin 1 on ISCV, this is the PWM switching wire to the ISCV, pin 2 on the ISCV gets a constant live feed from t87 of the fuel pump relay.
Pin 20 on the ECU is the ECU power, which is supplied from t87 on the ECU relay (next to the fuel pump relay).
ECU pin 31 goes to pin 2 on Air Temp Sensor (ATS), ECU pin 11 goes to pin 1 on ATS. ECU pin 11 is a common ground return and connects to the ATS, TPS, MAP, & ECT.
Old Oct 31, 2011 | 09:11 PM
wes's Avatar
wes
Here's the wiring diagram of the Fuel Pump and ECU (Main) relays:
Old Oct 31, 2011 | 11:58 PM
MGZS1952's Avatar
MGZS1952
Thanks Wes I really appreciate yor help I can crack on and sort the wiring then get down to the idle problem
thanks
Kev
JK12
33
Apr 26, 2021 12:09 PM
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
hopper350
Sep 4, 2015 12:53 AM
